Installs a license key file on ExtremeSwitching 5420 and 5520 series switches.
| file | Specifies providing the license key file. |
| filename | Specifies the name of the license key file. The file name must have a .lic extension. |
| slot | For stacks and Extended Edge Switching, specifies providing a slot for the license key file. |
| slot | For stacks and Extended Edge Switching, specifies the slot for the license key file. |
N/A.
This command installs all of the license features contained in the selected license file to the specified slot (node).
To uninstall a license, use the command uninstall license file filename [{revoke revocation_file} | withhold ]{slot slot}.
To uninstall a specific feature, use the command uninstall license product product_name [revoke revocation_file | withhold] {slot slot}
The following example installs a license using the license file mylicense.lic:
# install license file mylicense.lic
This command was first available in ExtremeXOS 31.1.
